New member Username: Nono5907Post Number: 3 Registered: May-13 | Bonjour je viens d'acheter une saxo pour ma conjoint et l'autoradio demande un code, le numéro de série est vf7s0hfxb57418483 |
Gold Member Username: OpelopPost Number: 1227 Registered: Sep-12 | Nolan New member Username: Nono5907 serial numbers from radio please contakt me http://forum.kody-radio.pl |
New member Username: Nono5907Post Number: 4 Registered: May-13 | Bonjour l'autoradio est encore mont� donc je ne l'ai pas, |
New member Username: Nono5907Post Number: 5 Registered: May-13 | Bonjour voici les infos de mon autoradio de ma saxo, ModÚle autoradio PU-2294B (D) Numéro de série autoradio CL040220749044 Numéro série voiture : vf7s0hfxb57418483 Merci |
Gold Member Username: OpelopPost Number: 1230 Registered: Sep-12 | Nolan New member Username: Nono5907 Your radio is made by CLARION and the only CLARION code that can be calculated (using a serial number ) anywhere on the Internet is if your radio also has a BARCODE SERIAL NUMBER beginning with C 7000000 + + + + on a separate label somewhere on the metal casing. (Note ...not beginning with CL.) If not then it will only be available from your Main Dealer or a Decoding Service or your local Car Radio / Audio Store who will connect a laptop to read/recode the memory chip (EEPROM) inside your radio. |
