Renault megane scenic 05 cd player code
Username: Emma3151991
Hi the Battery died and ever since I have needed a code for the CD player and its driving me mad the model no is RENEDW132-10. RNRD045014782. And the prod no is FD0705030157882 .
I would really appreciate the help if someone knows the code.
Thank you
Username: Opelop
Post Number: 1284
Emma
Please, letters/numbers from the main bar code 8200xxxxtt123, 7200xxxxxtt123 or security code, as Q123 or T0U123
contakt me http://forum.kody-radio.pl
The barcode is 8200300859tt995
Username: Opelop
Post Number: 1285
Emma
CODE 6085
Its still beeping as thoughts wrong
Is there any other possible code it can be or is there a certain button I have to press once I've entered the code
Thank you
Username: Dekster
POLAND
Post Number: 964
Emma
Code Entry as Follows:
Switch Radio On - Display Shows
" CODE " Then " 0000 "
Press preset " 1 " repeatedly for 1st Digit
Press preset " 2 " repeatedly for 2nd Digit
Press preset " 3 " repeatedly for 3rd Digit
Press preset " 4 " repeatedly for 4th Digit
If the correct code number is now shown
Press and hold preset " 6 " To Enter
" 0000 " with the 1st digit flashing
Rotate " Thumbwheel " For Correct Digit
Press " ¬ " On The Stalk Control To Enter
Press And Hold " ¬ " Until A Beep Is Heard
contact me
http://koddoradia.pl/
Username: Opelop
Post Number: 1287
Emma
remove radio from car
first enter wrong code after that enter good code
Username: Dekster
POLAND
Post Number: 965
Emma
Remove the radio from the car and after all the letters and numbers on any of the labels, bar codes, and stamped metal body. To remove the radio can be found here:
http://www.fitaudio.com/index.php?CategoryID=13
contact me
Username: Opelop
Post Number: 1289
Emma your code is 6085
