New member Username: Note123Post Number: 1 Registered: May-13 | If anyone can help, please can you find out the code to my Dad's car radio if possible. There has been a delay in receiving the handbook pack as we are still waiting for the previous owners (Motobility) to forward it on to us that why I am reluctant to go to the main dealer just yet. It is requesting a code after the battery was disconnected for some routine maintenance. I have so far got the following information from the unit itself... Nissan Part No: 28185 BH10A Model No: PN-3001P-B Serial No: CL0819 9 0203771 Design Note No: T1U310 Clarion. Single CD player Thank you in advance. |
Silver Member Username: DeksterPOLAND Post Number: 902 Registered: Sep-12 | note123 New member Username: Note123 Your radio is made by CLARION and the only CLARION code that can be calculated (using a serial number ) anywhere on the Internet is if your radio also has a BARCODE SERIAL NUMBER beginning with C 7000000 + + + + on a separate label somewhere on the metal casing. (Note ...not beginning with CL.) If not then it will only be available from your Main Dealer or a Decoding Service or your local Car Radio / Audio Store who will connect a laptop to read/recode the memory chip (EEPROM) inside your radio. contact me http://koddoradia.pl/ |
