Help buying a DVD receiver?
Username: Impala63rag
DD 9512s , Orion d5000
Post Number: 776
I am looking to buy a double din DVD player for a 2009 Ford Fusion, and not sure which one to get, or from where. I'm on a budget, looking to spend 250-300 for the head unit. I would also need help with a couple speakers. not changing them all out, just either the front or the back. I am not sure which are more important. The equipment needed for the job, and where to buy it. wiring harness, dash kit, antenna adapter, back up camera kit, etc.. also, how much more would it cost to add a navigation system to it?
Post Number: 777
Almost forgot, I would need a bypass for the parking brake feature. So I suppose it would need to be friendly to doing that.
Username: Georgeallen
Richmond, Texas Usa
actually we can't suggest you a specific sites but i think google will help you for that.
Need to Register?
Forgot Password?
Enable HTML code in message
