New member Username: Baldwin90Roscommon Post Number: 1 Registered: Apr-13 | Hi There'Can anyone help'' I lost my car radio code when i disconnected my battery.... my radio is a Philips R660 Serial no:RG349FV1118684 22DC349/60B 9022 213 49601 M/ch:118227 |
Silver Member Username: DeksterPOLAND Post Number: 870 Registered: Sep-12 | Andrew brennan New member Username: Baldwin90 Sorry....your code will only be available from the Main Dealer database or the unit will have to be taken into a Radio Decoding Service It is unlikely to be available for free or cheap from anywhere on the Internet contact me http://koddoradia.pl/ |
Gold Member Username: OpelopPost Number: 1105 Registered: Sep-12 | Andrew brennan New member Username: Baldwin90 CODE 5738 contakt me http://forum.kody-radio.pl |
New member Username: Baldwin90Roscommon Post Number: 2 Registered: Apr-13 | Via the power of google the proceedure is: Switch Radio On - Display Shows " CODE " Press Preset " 1 " and the display will show " 0 - - - " Press Tuning Up Button " > " For Correct Digit Press Preset " 1 " to Enter Press Tuning Up Button " > " For Correct Digit Press Preset " 1 " to Enter Press Tuning Up Button " > " For Correct Digit Press Preset " 1 " to Enter Press Tuning Up Button " > " For Correct Digit If the correct code number is now shown Press Preset " 1 " to Ente........ Hi Opelop Thanks for trying'' I tried it with no look'' I'll try again later just incase i intered it wrong.... If anyone may have a code for this' i would be greatful!.... Regards AndyPhilips R660 Serial no:RG349FV1118684 22DC349/60B 9022 213 49601 M/ch:118227 |
Silver Member Username: DeksterPOLAND Post Number: 871 Registered: Sep-12 | Andrew brennan New member Username: Baldwin90 5738 code wrong Sorry....your code will only be available from the Main Dealer database or the unit will have to be taken into a Radio Decoding Service It is unlikely to be available for free or cheap from anywhere on the Internet Try read eeprom contact me http://koddoradia.pl/ |
New member Username: Baldwin90Ireland Post Number: 3 Registered: Apr-13 | Hi Dekster'Thanks for the advice' I'll hold out for the moment & see if anyone else might be able to find it....Andy!!.... Philips R660 Serial no:RG349FV1118684 22DC349/60B 9022 213 49601 M/ch:118227 |
