New member Username: XaponPost Number: 1 Registered: Apr-13 | Can anyone help me wit the security code for a Becker Traffic Pro high speed, bought it on a booth sale and tried some calculators with no success, only available numbers on screen are from 1 to 6 Serial of the radio is 45007434 The already tested codes (with no luck) are 11244 and 22142. Kind regards Ron |
Gold Member Username: OpelopPost Number: 1108 Registered: Sep-12 | Xapon New member Username: Xapon CODE 66322 contakt me http://forum.kody-radio.pl |
New member Username: XaponPost Number: 2 Registered: Apr-13 | Thanks Opelop! great this code does work. But... I do need to bring the radio to a repairman, it won't eject the audio CD and keeps asking for the nav CD or displays "Phone" so it seems that it is a radio with some malfunctions.. Not sure what to do, have it repaired or throw it away and buy another one. I have had the same radio system in a previous Audi and was really enthusiastic about it. that was the only reason I bought it second-hand yesterday. Also it is missing the GPS antenna... so I'll sleep over it and then make up my mind. Thanks anyway, it was worth trying. Kind regards, Ron |
