alright im planning on buying two kicker s15l7 solo-barics and im wondering should i get the 2 ohms or 4 ohms and im also looking for an really good amp to push these speakers
Jake
i was looking at an audiobahn a2300hct but i would also like to know how to run them so i get the 2400 @ 1 ohms power this is going in the back of a discovery II so i mean i have alot of room for everything just wondering thx guys
Jake
sry i mean the 1200 @ 1 ohms stereo i guess is what it would run as?
motoman22
Jake, depends on which amp you want.
If the amp you want is stable at 4 ohms mono then get the 4-ohm subs.
If the amp you want is stable at 2 ohms mono then get the 2-ohm subs.
If the amp you want is stable at 1 ohm mono then get the 4-ohm subs.
If the amp you want is stable at 0.5 ohm mono then get the 2-ohm subs.
The lower the resistance (ohm rating) the more power you make but the more power the amp requires (and the more heat it generates, etc..)
Jake
thank you very much do you have a reccommended amp?
