New member Username: AiisunsPost Number: 1 Registered: Mar-13 | Hi, I have a primastar van in which the cigarette lighter has packed up, like an idiot i looked to see if the fuse had blown and pulled out the fuse which controls the radio and alarm. Now have no radio as it needs a code and the only 4 digit code which is randomly handwritten in the servicing book does not work :-(, I have the security code of Y535 from the radio, If I could get the 4 digit code it would be much appreciated. |
Silver Member Username: OpelopPost Number: 885 Registered: Sep-12 | Alistair New member Username: Aiisuns CODE 1406 contakt me http://forum.kody-radio.pl |
New member Username: AiisunsPost Number: 2 Registered: Mar-13 | hi, thanks, that code mates the random code in the servicing book but it wont go in, I assume I am putting it in right? I press 1 until 1 appears 2 until 4 appears etc etc but it wont come on and if I press 5 it just does an angry beep. |
New member Username: AiisunsPost Number: 3 Registered: Mar-13 | sorted it now cheers for your help, forgot to press and hold 6 thanks for your help. |
