New member Username: Asghar80Post Number: 1 Registered: Oct-12 | Radio Code Needed Hi , I need a radio code for my K12 Details are BP334947237729 7643349318 thanks |
Silver Member Username: DeksterPOLAND Post Number: 144 Registered: Sep-12 | Code is: 4769 contact me: e-mail: stefan15@poczta.onet.pl I greet. |
New member Username: Asghar80Post Number: 2 Registered: Oct-12 | thanks for ur code i have 1 more nissan micra. I need a radio code for my K12 Details are BP234631952772 7642346318 thanks |
Silver Member Username: DeksterPOLAND Post Number: 146 Registered: Sep-12 | Reminder :..NO MULTIPLE CODE REQUESTS ON THIS FORUM Single free code request for personal use only (one code request every 6 months minimum) This is for security reasons in order to prevent abuse by traders+dealers, car radio thieves and other chancers Sorry if you are one of the honest ones ! contact me: e-mail: stefan15@poczta.onet.pl I greet. |
New member Username: PjflyingfoxPost Number: 1 Registered: Oct-12 | Radio Code Needed Hi , my radio was disconnected (Nissan Micra 2003) and now it's asking for a code. I have the manual, which came with a 'radiopass' sticker with the following details - BP2346 - Model 32512794 - Serial No 6122 - Safety No 28 185 AX611 - Part No (I think) Can anyone help provide the code to unlock? Thanks Penny |
Silver Member Username: DeksterPOLAND Post Number: 174 Registered: Sep-12 | Code is: 6122 contact me: e-mail: stefan15@poczta.onet.pl I greet. |
New member Username: Firefly9859Post Number: 1 Registered: Oct-12 | Hello, Flat battery leaves me needing a code please. Micra 03 Blaupunkt BP334936357983 Nissan MM CD-K 7643 349 318 e1 022458 383F(In Blue) Many thanks! |
Silver Member Username: DeksterPOLAND Post Number: 232 Registered: Sep-12 | Code is: 8521 contact me: e-mail: stefan15@poczta.onet.pl I greet. |
New member Username: SarahcPost Number: 1 Registered: Oct-12 | Radio Code Needed Hi, my Nissan Mirca K12 2004 Battery died. I'm in need of a code to fix this. Can you help? Blaupunkt BP234631952772 Nissan MM CD-K 7642346318 e1 022458 Thank you in advance |
Bronze Member Username: OpelopPost Number: 82 Registered: Sep-12 | 4389 radio code help my e-mail: opelop@onet.pl |
New member Username: Glennp50Post Number: 1 Registered: Nov-12 | Hi after a battery change I was locked out of the radio. Can you please help? Nissan k12 micra The ration code is BP334947338249 The other code is 7643349318 Many thanks Glennp |
Silver Member Username: DeksterPOLAND Post Number: 362 Registered: Sep-12 | Your code is : 8688 contact me: http://koddoradia.pl/ e-mail: stefan15@poczta.onet.pl I greet. |
New member Username: Glennp50Post Number: 2 Registered: Nov-12 | Thanks Dekster |
New member Username: BleumePost Number: 1 Registered: Nov-12 | hello, i need a radio code from a nissan micra K12 lost code after changing the battery BP code is : BP334936395179 7643349318 |
New member Username: BleumePost Number: 2 Registered: Nov-12 | hello, i need a radio code from a nissan micra K12 lost code after changing the battery BP code is : BP334936395179 7643349318 |
Silver Member Username: DeksterPOLAND Post Number: 379 Registered: Sep-12 | bleume New member Username: Bleume Your code is : 7539 contact me: http://koddoradia.pl/ e-mail: stefan15@poczta.onet.pl I greet. |
New member Username: BleumePost Number: 3 Registered: Nov-12 | hello, sorry code does'nt work had one number wrong from the bp code the good number is: BP334936395719 |
Platinum Member Username: RegroosterPost Number: 11475 Registered: Aug-08 | bleume New member Username: Bleume try code 9747 |
New member Username: AngelinneCj, Österreich Post Number: 1 Registered: Dec-12 | Hi after a battery change I was locked out of the radio. Can you please help? Nissan k12 micra ,C 01 I do not know how to pull off the tape recorder to read the code on it,other data does not help that you can give me the code? |
Silver Member Username: DeksterPOLAND Post Number: 532 Registered: Sep-12 | angelinne New member Username: Angelinne Enter all numbers from radio Contact me http://koddoradia.pl/ |
Silver Member Username: OpelopPost Number: 175 Registered: Sep-12 | angelinne New member Username: Angelinne maybe this site can help you http://www.fitaudio.com/ contakt me http://forum.kody-radio.pl |
New member Username: AngelinneCj, Österreich Post Number: 2 Registered: Dec-12 | How can I see The numbers of those radio? Have to pull someone out radio? |
Silver Member Username: OpelopPost Number: 176 Registered: Sep-12 | yes |
New member Username: AngelinneCj, Österreich Post Number: 3 Registered: Dec-12 | 2004 it the car ! |
New member Username: AngelinneCj, Österreich Post Number: 4 Registered: Dec-12 | I understand ... otherwise without that number so I know how to code! Means you have to find a man to pull it off ... |
New member Username: AngelinneCj, Österreich Post Number: 5 Registered: Dec-12 | RADIO is Nissan RDS |
Platinum Member Username: RegroosterPost Number: 11525 Registered: Aug-08 | Remove the radio and post all the letters and numbers on any labels or stamped in the casing Nissan removal instructions can be found here http://www.fitaudio.com/index.php?CategoryID=25 |
New member Username: Dan_707Post Number: 1 Registered: Jan-13 | Hi I need a radio code for a micra k12 after disconnecting the battery The bp code is bp334947263898 The part code is 7643349318 Any help would be much appreciated |
Silver Member Username: DeksterPOLAND Post Number: 659 Registered: Sep-12 | Dan New member Username: Dan_707 CODE 8685 contact me http://koddoradia.pl/ |
Silver Member Username: OpelopPost Number: 404 Registered: Sep-12 | Dan New member Username: Dan_707 CODE 8685 contakt me http://forum.kody-radio.pl |
New member Username: RassytPost Number: 1 Registered: Feb-13 | Hello! After changing battery in my car, Blaupunkt radio is asking for the code. My car is Nissan Micra K12 2003. The numbers of radio are: BP234620852442 7642346318 |
Silver Member Username: OpelopPost Number: 623 Registered: Sep-12 | rassyt New member Username: Rassyt CODE 7607 contakt me http://forum.kody-radio.pl |
New member Username: RassytPost Number: 2 Registered: Feb-13 | the silence in my car is finally killed! Thank you!! |
New member Username: Slobo10Post Number: 2 Registered: Feb-13 | Hello! After changing battery in my car, Blaupunkt radio is asking for the code. My car is alfa romeo 156 1.9JTD 02' BP037622620477 BP-Nr. 7 640 376 316 Prod Nr. Fiat 156 034 208 0 |
Silver Member Username: OpelopPost Number: 631 Registered: Sep-12 | slobo10 New member Username: Slobo10 CODE 6564 contakt me http://forum.kody-radio.pl |
New member Username: Slobo10Post Number: 3 Registered: Feb-13 | Thank you boys I appreciate your job. Code is working. |
New member Username: Captain_slogPost Number: 1 Registered: Feb-13 | Hi Not for the first time I've managed to lose a radio code. It happened when I had to fit a new distributor to my wife's Micra. Can anybody help please? The serial number is BP334947231564 |
Silver Member Username: OpelopPost Number: 636 Registered: Sep-12 | Captain Slog New member Username: Captain_slog CODE 9344 contakt me http://forum.kody-radio.pl |
New member Username: ShibekPost Number: 6 Registered: Sep-12 | NEED CODE FOR BLAUPUNKT RADIO FOR VW 815 7 642 218 360 VWZ1Z1E9056670 6X0 035 153 A THENKSS |
Silver Member Username: DeksterPOLAND Post Number: 776 Registered: Sep-12 | zlatko postolovski New member Username: Shibek Duplicate post....Already answered contact me http://koddoradia.pl/ |
Silver Member Username: OpelopPost Number: 638 Registered: Sep-12 | zlatko postolovski New member Username: Shibek sorry we can't help Main Dealer or a Decoding Service only for this code contakt me http://forum.kody-radio.pl |
New member Username: Winnie_ukPost Number: 1 Registered: Feb-13 | Hi, Need radio code for Nissan Micra 2005. BP 3349 4 7251 902 Cheers in advance!!! |
Silver Member Username: OpelopPost Number: 641 Registered: Sep-12 | winnie New member Username: Winnie_uk CODE 7425 contakt me http://forum.kody-radio.pl |
New member Username: AngelinneCj, Österreich Post Number: 6 Registered: Dec-12 | Hi, After several months of waiting ... I finally found someone to dismantle my dashboard I need a radio code..........plssssssss...... for my K12 BP 334936389995 Nissan MM CDK 7643349318 022 458 Thanks!!! |
Silver Member Username: OpelopPost Number: 662 Registered: Sep-12 | angelinne New member Username: Angelinne CODE 2707 contakt me http://forum.kody-radio.pl |
New member Username: AngelinneCj, Österreich Post Number: 7 Registered: Dec-12 | God give you health ..... I'm glad I ams what ru music in the car after so many months .... thankssssssssssssssss |
New member Username: Emran80Post Number: 2 Registered: Mar-13 | hi Guys, I have lost the code for my radio on a nissan micra reg Ao03ues . The BP code is BP 234732020306. REGARDS |
Silver Member Username: OpelopPost Number: 722 Registered: Sep-12 | Emran New member Username: Emran80 CODE 3695 contakt me http://forum.kody-radio.pl |
Silver Member Username: OpelopPost Number: 723 Registered: Sep-12 | Emran New member Username: Emran80 CODE 3695 contakt me http://forum.kody-radio.pl |
Silver Member Username: OpelopPost Number: 724 Registered: Sep-12 | Emran New member Username: Emran80 CODE 3695 contakt me http://forum.kody-radio.pl |
New member Username: MilitairePost Number: 1 Registered: Mar-13 | Please can I have the radio code for my micra k12 Chassis SJNECAK12U1164282 Engine 026032 Serial number BP 334 936 366 288 Thank you for your help |
Silver Member Username: OpelopPost Number: 840 Registered: Sep-12 | Iain New member Username: Militaire CODE 3543 contakt me http://forum.kody-radio.pl |
