Blaupunkt 2020-Holden Vectra
Username: Mike5196
Perth, W.A Australia
Hi all, need some help- cleaned my battery terminals and now need a code for stereo.Put in code I found 3 times but must be wrong code as didn't work. I think I have found the right code now but cannot put it in as stuck at 'SAFE 7'. Holding down 'AS' button doesn't help. Disconnected battery again but still stuck at 'SAFE 7'. Any advice appreciated. Thanks
Username: Regrooster
Post Number: 11545
Press AS and ON button at the same time
Leave SWITCHED ON...UNDISTURBED for as long as it takes to automatically reset itself
This will take up to 1 hour
Then enter the code and press the AS Button again
Make sure you have the correct code
Username: Mike5196
Thanks reg Rooster, will give that a go.
Username: Mike5196
Absolutely brilliant. Got my stereo going again following your instrctions and using correct PIN. Thanks RegRooster for your invaluable help.
