Renault grand scenic 55 plate radio code needed
Username: Ells29
does anybody know the code for my 55 plate renault grand scenic? lost code due to battery replacement?
any help would be greatly appreciated, codes are as follows
RNRD4050023551
RENRDW231-10
FD0405390023551
8200367490T
Q072- SECURITY
hope somebody can help?
thanks
Username: Dekster
POLAND
Post Number: 772
ellie.b
Username: Ells29
CODE 9942
contact me
http://koddoradia.pl/
Username: Opelop
Post Number: 630
ellie.b
Username: Ells29
CODE 9942
contakt me http://forum.kody-radio.pl
Username: Ells29
thankyou Dekster i will try that now, but can i ask how i press enter with the code? thankyou
Username: Dekster
POLAND
Post Number: 773
Code Entry as Follows:
ellie.b
Username: Ells29
http://www.dndservices.co.uk/product.php?productid=6254&cat=0&page=1
Switch Radio On - Display Shows
" CODE "
Then " 0000 " with the 1st digit flashing
Rotate " Thumbwheel " For Correct Digit
Press " ¬ " On The Stalk Control To Enter
If the correct code number is now shown
Press And Hold " ¬ " Until A Beep Is Heard
contact me
Username: Ells29
thankyou for the quick response again, i have located the thumbwheel and can correcrly enter the code, however maybe i am being dumb but i cannot locate the "A¬" button??
Username: Opelop
Post Number: 632
1 x number of keystrokes = first digit of the code
2 x number of keystrokes = second digit of the code
3 x number of keystrokes = the third digit of the code
4 x number of keystrokes = the fourth digit of the code
6 acceptance
Username: Dekster
POLAND
Post Number: 774
ellie.b
Username: Ells29
" CODE " Then " 0000 "
Press preset " 1 " repeatedly for 1st Digit
Press preset " 2 " repeatedly for 2nd Digit
Press preset " 3 " repeatedly for 3rd Digit
Press preset " 4 " repeatedly for 4th Digit
Press and hold preset " 6 " To Enter
contact me
