New member Username: Ells29Post Number: 1 Registered: Feb-13 | does anybody know the code for my 55 plate renault grand scenic? lost code due to battery replacement? any help would be greatly appreciated, codes are as follows RNRD4050023551 RENRDW231-10 FD0405390023551 8200367490T Q072- SECURITY hope somebody can help? thanks |
Silver Member Username: DeksterPOLAND Post Number: 772 Registered: Sep-12 | ellie.b New member Username: Ells29 CODE 9942 contact me http://koddoradia.pl/ |
Silver Member Username: OpelopPost Number: 630 Registered: Sep-12 | ellie.b New member Username: Ells29 CODE 9942 contakt me http://forum.kody-radio.pl |
New member Username: Ells29Post Number: 2 Registered: Feb-13 | thankyou Dekster i will try that now, but can i ask how i press enter with the code? thankyou |
Silver Member Username: DeksterPOLAND Post Number: 773 Registered: Sep-12 | Code Entry as Follows: ellie.b New member Username: Ells29 http://www.dndservices.co.uk/product.php?productid=6254&cat=0&page=1 Switch Radio On - Display Shows " CODE " Then " 0000 " with the 1st digit flashing Rotate " Thumbwheel " For Correct Digit Press " ¬ " On The Stalk Control To Enter Rotate " Thumbwheel " For Correct Digit Press " ¬ " On The Stalk Control To Enter Rotate " Thumbwheel " For Correct Digit Press " ¬ " On The Stalk Control To Enter Rotate " Thumbwheel " For Correct Digit If the correct code number is now shown Press And Hold " ¬ " Until A Beep Is Heard contact me http://koddoradia.pl/ |
New member Username: Ells29Post Number: 3 Registered: Feb-13 | thankyou for the quick response again, i have located the thumbwheel and can correcrly enter the code, however maybe i am being dumb but i cannot locate the "A¬" button?? |
Silver Member Username: OpelopPost Number: 632 Registered: Sep-12 | 1 x number of keystrokes = first digit of the code 2 x number of keystrokes = second digit of the code 3 x number of keystrokes = the third digit of the code 4 x number of keystrokes = the fourth digit of the code 6 acceptance contakt me http://forum.kody-radio.pl |
Silver Member Username: DeksterPOLAND Post Number: 774 Registered: Sep-12 | ellie.b New member Username: Ells29 Code Entry as Follows: Switch Radio On - Display Shows " CODE " Then " 0000 " Press preset " 1 " repeatedly for 1st Digit Press preset " 2 " repeatedly for 2nd Digit Press preset " 3 " repeatedly for 3rd Digit Press preset " 4 " repeatedly for 4th Digit If the correct code number is now shown Press and hold preset " 6 " To Enter contact me http://koddoradia.pl/ |
