Need help with mid bass drivers
Username: Destroyerzx1
I have some old xr jl 650 components. the tweeters went out so i bought some zr's and now one of the midbass drivers have gone out and so I'm looking to replace the midbass and run it off the jl crossover. I called jl but they don't make them anymore so I would have to buy the c5 which is $160 for one driver.I also called a coil repair shop and they wont touch jl. so I need to replace the midbass but don't want to buy one then have the other go. so I'm looking for a set to replace the midbass but I don't want to spend more then $160 for a pair of replacements. what would you recommend so far I'm deciding between
http://www.sonicelectronix.com/item_65567_Pioneer-TS-M650PRO.html
http://www.sonicelectronix.com/item_27340_RE-Audio-RE6.5C.html
I don't have to need for the tweeters or the crossover but finding 6.5 mid drivers seperatly or in pairs is difficult.
Username: Joe1234
Post Number: 1775
http://www.fixmyspeaker.com/
they told me they can't do anything for me so I bought some cdt hd mid drivers.
Username: Joe1234
Post Number: 1785
Like better CDT. Congrats.
the local hardware store was having a sale so i decided to use 3/4 mdf. had enough to make 3 box's plus some extra.
Need to Register?
Forgot Password?
Enable HTML code in message
