New member Username: Lorrainegilmour24Post Number: 1 Registered: Feb-13 | hi my battery died and i need a code to reset it can anyone help please model 22DC279/62P TOU 932 RN279FY0098218 PROD NO FD0100230098218 any suggestions would be great thanks |
Silver Member Username: OpelopPost Number: 563 Registered: Sep-12 | lorraine.gilmour24 New member Username: Lorrainegilmour24 CODE 5078 contakt me http://forum.kody-radio.pl |
Silver Member Username: DeksterPOLAND Post Number: 740 Registered: Sep-12 | lorraine.gilmour24 New member Username: Lorrainegilmour24 CODE 5078 contact me http://koddoradia.pl/ |
New member Username: Lorrainegilmour24Post Number: 2 Registered: Feb-13 | Thanks so much wasnt expecting a reply so quick your a wee angel |
New member Username: Moses2013Post Number: 1 Registered: Feb-13 | Hello, Please help if you know what would be a good way to set up a two-battery system to be used in my Chinese-made van. I live in Northeast China, where it is so cold in the winter, that the battery will not turn the engine over. I use an electric heat pump (installed externally to the water pump) and powered by an AC source, to run the water until the engine block warms-up and the engine can be started. However, if I am driving somewhere and have to turn the engine off for more than 2 hrs, it is back to being frozen again. This is when I need the extra power to get it started. Is it possible to use both batteries for this, i.e., to get the engine started in extreme conditions? What kind of wiring system should be used for this? If both batteries cannot be used simultaneously, what would be a good way to set them up, so as to run them independently and have the extra voltage always available? Thank you so much for your help. |
Silver Member Username: DeksterPOLAND Post Number: 742 Registered: Sep-12 | Moses New member Username: Moses2013 Sorry but there is a section devoted to the radio code contact me http://koddoradia.pl/ |
Silver Member Username: OpelopPost Number: 565 Registered: Sep-12 | lorraine.gilmour24 New member Username: Lorrainegilmour24 try here https://www.ecoustics.com/electronics/forum/car-audio/39.html contakt me http://forum.kody-radio.pl |
