Posted on I found a great deal on the Take 5.2 without a sub. I need a good sub ($350 or less) to go with these speakers and the H/K AVR 330 receiver. Your opinions are appreciated. Thanks. P.S. If you recommend a sub, please also recommend a place to buy it (either a big chain or online) if you can. |
Derek |
Posted on JBLs are easy to find (Best Buy). If you can hunt one down Mission makes some good under $350 subs. www.partsexpress.com sells some good sub kits. |
Posted on I forgot to mention that my room is 16x20 (16x16 listening area) with 17' ceilings. Is the Energy s8.2 a good sub? |
