New CD player
Username: Oleg
West Covina, CA USA
Post Number: 1427
Hi all,
my JVC CD changer crapped out again and I only get sound from the right speakers when it's set as the source. MY CD player is also wearing out - turns off randomly. I'm ready to get away from JVC. I was looking at Pioneer DEH-x9500BHS and Alpine CDE-HD138BT. Pioneer looks a bit cooler, but both USB connections are in the back - would I just have a USB cable sticking out through a crack if I wanted to connect a memory stick to it? Which one do you guys recommend? I'm also open to other suggestions! Thank you!
Need to Register?
Forgot Password?
Enable HTML code in message
