New member Username: LynettegalbraithPost Number: 1 Registered: Jan-13 | Has anyone got the code for a renault scenic 2001 Model22DC279/62P RN279F10214399 FD0301100214399 7700434425TG704 7700434425 Thanks |
Silver Member Username: DeksterPOLAND Post Number: 655 Registered: Sep-12 | Lynette New member Username: Lynettegalbraith CODE 5879 contact me http://koddoradia.pl/ |
Silver Member Username: OpelopPost Number: 401 Registered: Sep-12 | Lynette New member Username: Lynettegalbraith CODE 5879 contakt me http://forum.kody-radio.pl |
New member Username: LynettegalbraithPost Number: 2 Registered: Jan-13 | Sorry code 5879 didn't work |
Silver Member Username: DeksterPOLAND Post Number: 657 Registered: Sep-12 | Lynette New member Username: Lynettegalbraith You did good numbers? contact me http://koddoradia.pl/ |
New member Username: LynettegalbraithPost Number: 3 Registered: Jan-13 | When I put 5879 in I hold the number 6 button to save the code and it gives me the message " others " and the radio still doesn't work can anyone help please |
Silver Member Username: DeksterPOLAND Post Number: 658 Registered: Sep-12 | Lynette New member Username: Lynettegalbraith Code Entry as Follows: Switch Radio On - Display Shows " CODE " Press " ¬ " On The Stalk Control To Enter " 0000 " Rotate " Thumbwheel " For Correct Digit Press " ¬ " On The Stalk Control To Enter Rotate " Thumbwheel " For Correct Digit Press " ¬ " On The Stalk Control To Enter Rotate " Thumbwheel " For Correct Digit Press " ¬ " On The Stalk Control To Enter Rotate " Thumbwheel " For Correct Digit If the correct code number is now shown Press And Hold " ¬ " Until A Beep Is Heard contact me http://koddoradia.pl/ |
Silver Member Username: OpelopPost Number: 403 Registered: Sep-12 | code accept this is user options contakt me http://forum.kody-radio.pl |
New member Username: LynettegalbraithPost Number: 4 Registered: Jan-13 | Thank you very much my radio is working perfect didn't know how to use the Stalk once again thanks |
