Sterio code primastar
Username: Baz98765
Carrickmacross , Monaghan Ireland
Hi I'm wondering can you help me my battery went flat on my van today and When I jump started it the stereo needed a 4 digit code. I loosened out the radio so I could get the information on the side if this helps. I travel 2 hrs to work most mornings so I really need it. The information on the side are as follows:
Renault is the make of the radio
Model no 22DC279/62
Security H745
RN 279F50511443
PROD NO FD1105320511443
Under barcode 7700433948TH745
I hope this helps it would be greatly appreciated if I could get the code.
Thank you
Username: Opelop
Post Number: 375
Barry lambe
Username: Baz98765
CODE 2845
contakt me http://forum.kody-radio.pl
Username: Baz98765
Thanks opelop works perfect. Great job
