New member Username: Benlewis38Post Number: 1 Registered: Jan-13 | Battery been replaced in my fiesta and i need to unlock the radio again! serial number is m135038 would be very greatful if someone could help Many thanks |
Silver Member Username: OpelopPost Number: 288 Registered: Sep-12 | benlewis38 New member Username: Benlewis38 CODE 5714 contakt me http://forum.kody-radio.pl |
New member Username: Benlewis38Post Number: 2 Registered: Jan-13 | It worked thank you very much! |
New member Username: Gio2409Post Number: 1 Registered: Jan-13 | Hello i Need a Code for Radio ford 4500 RDS Eon please Serialnr . M101869. Thanks |
Silver Member Username: OpelopPost Number: 310 Registered: Sep-12 | Moataz zein New member Username: Gio2409 CODE 8714 contakt me http://forum.kody-radio.pl |
Silver Member Username: DeksterPOLAND Post Number: 602 Registered: Sep-12 | Moataz zein New member Username: Gio2409 Try code 8714 contact me http://koddoradia.pl/ |
New member Username: Gio2409Post Number: 2 Registered: Jan-13 | It Works )) Thanks a Lot for your fast Message in Germany Nobody Helps You they Just want Money Then they give you the Code .. |
New member Username: Stewy83Post Number: 1 Registered: Jan-13 | hi there i need my code for ford c-max radio.had some work done and now the radio is asking for a code.serial number is v011869 if anyone can help that would be great thanks |
Silver Member Username: DeksterPOLAND Post Number: 604 Registered: Sep-12 | stewy New member Username: Stewy83 Ford V Serial codes are not usually available for free from anywhere on the Internet (unless you can blag it for free from Ford) as they are not calculated using software but require access to the Ford factory database( via a Ford Dealer)...which is not commercially available as software. Otherwise try your Ford Dealer or a Radio Decoding Service http://www.ukbookshelf.co.uk/page1.html contact me http://koddoradia.pl/ |
Silver Member Username: OpelopPost Number: 312 Registered: Sep-12 | stewy New member Username: Stewy83 cheapest on e bay http://www.ebay.co.uk/itm/FORD-RADIO-CODES-ALL-V-NUMBERS-AVAILABLE-SONY-VISTIEON -RADIOS-2-99-/330781793234?pt=LH_DefaultDomain_3&hash=item4d04219bd2 contakt me http://forum.kody-radio.pl |
New member Username: Stewy83Post Number: 2 Registered: Jan-13 | cheers guys i had a feeling i was going to struggle when i saw it was a v code.the code i had written in the log book didnt work and now the radio is locked.the work was carried out at the ford garage anyway so i think its a case of me taking it back and kicking up a stink.fingers crossed no banging heads together is required;) thanks again |
