Ford radio code!
Username: Benlewis38
Battery been replaced in my fiesta and i need to unlock the radio again!
serial number is m135038
would be very greatful if someone could help
Many thanks
Username: Opelop
Post Number: 288
benlewis38
CODE 5714
contakt me http://forum.kody-radio.pl
It worked thank you very much!
Username: Gio2409
Hello i Need a Code for Radio ford 4500 RDS Eon please
Serialnr . M101869. Thanks
Username: Opelop
Post Number: 310
Moataz zein
Username: Gio2409
CODE 8714
Username: Dekster
POLAND
Post Number: 602
Moataz zein
Username: Gio2409
Try code 8714
contact me
http://koddoradia.pl/
Username: Gio2409
It Works )) Thanks a Lot for your fast Message in Germany Nobody Helps
You they Just want Money Then they give you the Code ..
Username: Stewy83
hi there i need my code for ford c-max radio.had some work done and now the radio is asking for a code.serial number is v011869
if anyone can help that would be great
thanks
Username: Dekster
POLAND
Post Number: 604
stewy
Username: Stewy83
Ford V Serial codes are not usually available for free from anywhere on the Internet (unless you can blag it for free from Ford) as they are not calculated using software but require access to the Ford factory database( via a Ford Dealer)...which is not commercially available as software.
Otherwise try your Ford Dealer or a Radio Decoding Service
http://www.ukbookshelf.co.uk/page1.html
contact me
Username: Opelop
Post Number: 312
stewy
Username: Stewy83
cheapest on e bay
http://www.ebay.co.uk/itm/FORD-RADIO-CODES-ALL-V-NUMBERS-AVAILABLE-SONY-VISTIEON -RADIOS-2-99-/330781793234?pt=LH_DefaultDomain_3&hash=item4d04219bd2
Username: Stewy83
cheers guys i had a feeling i was going to struggle when i saw it was a v code.the code i had written in the log book didnt work and now the radio is locked.the work was carried out at the ford garage anyway so i think its a case of me taking it back and kicking up a stink.fingers crossed no banging heads together is required;)
thanks again
