Radio code needed after battery and fuse changed
Username: Cooperzen
Hello,
My Clio needed a new fuse and battery, bought the car last year and I still can't find my service book and user manual even though I know I have one (somewhere).
It is a standard radio you get with a clio the barcode number is: 82006079157
Any help would be fantastic.
Username: Opelop
Post Number: 260
Cooper
Username: Cooperzen
Please, letters/numbers from the main bar code 8200xxxxtt123, 7200xxxxxtt123 or security code, as Q123 or T0U123
contakt me http://forum.kody-radio.pl
Username: Cooperzen
Thank you for the response, the other numbers on the unit are:
8200607915T R644-Security (below the large bar code)
8200 607 9151 --C (above bar code)
These codes are to the left of the bar codes
RNRDCA80040447
RENRDW330-00
FD0608090040447
Username: Dekster
POLAND
Post Number: 573
Cooper
Username: Cooperzen
Your code is : 8304
contact me
http://koddoradia.pl/
Username: Opelop
Post Number: 261
Cooper
Username: Cooperzen
CODE 8304
Username: Cooperzen
Hello,
Sorry, that code did not work for me.
Username: Opelop
Post Number: 263
8304 must be correct
Username: Cooperzen
Hello 8304 was correct, there was an earlier post since edited that suggested an 8 than a 4.
thank you very much for that.
My ears thank you!!!
Username: Atakan
Hello,
Who can help me for Clarion radio code?
Clarion
Model: PU2294A
Serial nr: CL040120757372
Thanks,
Atakan
The Netherlands
Username: Opelop
Post Number: 265
Your radio is made by CLARION and the only CLARION code that can be calculated (using a serial number ) anywhere on the Internet is if your radio also has a BARCODE SERIAL NUMBER beginning with C 7000000 + + + + on a separate label somewhere on the metal casing.
(Note ...not beginning with CL.)
If not then it will only be available from your Main Dealer or a Decoding Service or your local Car Radio / Audio Store who will connect a laptop to read/recode the memory chip (EEPROM) inside your radio.
Username: Atakan
So you can't help me?
