Code help
Username: Dshonda
99 Honda Accord CD player radio Std.
serial 98D135203
can you find the code with this?
Username: Dshonda
Took it apart to get more info:
Model # 39100-S84-A210
Ref# CQ-JH18101A
Hope this helps.
Thanks
Username: Dekster
POLAND
Post Number: 547
DES
Username: Dshonda
Enter 3 times random codes into the radio, to get it locked out Press (up arrow) then preset 1, the display should then show ---- , Use button 1,2,3 to enter a New desired code and then press and hold SDK button for 5 seconds to switch radio off.
Press and hold presets 1,4,6 to run radio on and keep them holding until SEC appears on the display.
Now enter the first 3 digits of the MASTER code
Press v (down arrow) then preset 1, the display should then show ---
Now enter the last 3 digits of the MASTER code
CODE MASTER 878410
Contact me
http://koddoradia.pl/
Username: Ambazo
Hi,
Can you help me, please
I lost the code number from my audio car
CLAIRON
model: PU-2325 A(B)
serial: CL041010206595
Thank you
Username: Dekster
POLAND
Post Number: 564
laurent
Username: Ambazo
HAPPY 2013
Your radio is made by CLARION and the only CLARION code that can be calculated (using a serial number ) anywhere on the Internet is if your radio also has a BARCODE SERIAL NUMBER beginning with C 7000000 + + + + on a separate label somewhere on the metal casing.
(Note ...not beginning with CL.)
If not then it will only be available from your Main Dealer or a Decoding Service or your local Car Radio / Audio Store who will connect a laptop to read/recode the memory chip (EEPROM) inside your radio.
contact me
Username: Vm28
Need help i need to know the code for blaupunkt cheyenne cm42 serial number:BP0253N1505460
Username: Opelop
Post Number: 238
Victor
Username: Vm28
CODE 1137
contakt me http://forum.kody-radio.pl
Username: Regrooster
Post Number: 11528
I don't think the BP Cheyenne can be decoded using the Serial Number as it uses an older solder tag system for its code.
http://codedradio.info/?i=bn&st=cheyenne
Try emailing
restoredclassic@aol.com
to see if they can help
Username: Arajic
help me
please code mercedes benz alpine audio 10 cd
AL291030533689
Username: Opelop
Post Number: 243
silver
Username: Arajic
VIN from car please
Username: Arajic
WDB1681091J956499
THANKS
HAPPY NEW YEAR
Username: Rick_willits33
I need code help for Jensen VM9215BT. Please help??!??
Username: Baro
I need code for stereo BLAUPUNKT CAR 300 E
7648852320
GM 0300X9412841 PLEASE HELP ME
thank you
Username: Dekster
POLAND
Post Number: 566
baro
Username: Baro
CODE 9015
contact me
