Key Code For 6000 CD player...
Username: Sinkom
Hi can someone help me?
I need the key code to unlock my ford fusion 6000 CD player.
Serial Number: V018646
Part Number: 6S61-18C815-AJ
I would appreciate your help. Thanks !!!!!!!!!
Username: Opelop
Post Number: 195
cheapest option buy serie v on ebay
http://www.ebay.co.uk/itm/FORD-RADIO-CODES-ALL-V-NUMBERS-AVAILABLE-SONY-VISTIEON -RADIOS-2-99-/330781793234?pt=LH_DefaultDomain_3&hash=item4d04219bd2
contakt me http://forum.kody-radio.pl
Username: Dekster
POLAND
Post Number: 542
SinKom
Username: Sinkom
Ford V Serial codes are not usually available for free from anywhere on the Internet (unless you can blag it for free from Ford) as they are not calculated using software but require access to the Ford factory database( via a Ford Dealer)...which is not commercially available as software.
See your PM message for cheap options
Otherwise try your Ford Dealer or a Radio Decoding Service
Contact me
http://koddoradia.pl/
Username: Regrooster
Post Number: 11526
Ford V codes are cheaper here
www.ukbookshelf.co.uk/fordv
