New member Username: MnkiiidPost Number: 1 Registered: Mar-13 | So I have 2 12inch JL Audio sub-woofers. I'm new to this car audio stuff and I don't know which brands of amplifiers are good and which ones aren't. I want a pretty good one for my woofers that allows them to hit deep bass and fairly loud. My price range is like $250 tops. Please help me! And thank you for posting. |
Gold Member Username: Joe1234Post Number: 1788 Registered: May-09 | For the w3-w6 series: Key to deep bass is the enclosure, for two subs make a box 4 cubes net 54 inches of port area tuned to 32Hz to get that. Likely this amp since you will have to wire to 2 ohm: http://www.sonicelectronix.com/item_44471_MB-Quart-ONX1.2000D.html |
New member Username: MnkiiidPost Number: 2 Registered: Mar-13 | Well, I have already made a box customarily to fit under the backseat of my truck. And I honestly I didn't know that the box made the bass difference. But the I made is i think 4 feet long and there is about a 2 foot space between the 2 subs.. |
