Need help lost philips radiosat 6010 code
Username: Biggie_3
Varna, Bulgaria
hi can anyone help i need the radiosat 6010 code for
philips 22dc 461 621
9022 214 61624
PA4Bis 4x15w RDS
FD 09 99 05 41567
PROD NO:FDC99905
barcode - 7700433072w3
and one more question , how can i reset the radio to avoid the waiting for the code 32 min , cause i think i blocked it , maybe if i unplug the accumulator ?
thanks for the help
Username: Regrooster
Post Number: 11483
Sorry.......this is insufficient information
Quote the 14 character SERIAL NUMBER beginning with
PH* * * * * * * * * * * * found stamped in the metal casing.
Also quote the SECURITY NUMBER. This is found on a label on the metal casing in the format TOA123 or TA123 or just A123 at the end of a barcode
If in doubt post ALL the letters+numbers on any labels or barcodes
To reset it after wrong codes then it has to be left SWITCHED ON...UNDISTURBED until it has automatically reset itself.
This can take an hour or longer.
There is no other method
Username: Biggie_3
Varna, Bulgaria
i think i wrote everything on the paper , but tomorrow ill check and post all the info
Username: Biggie_3
Varna, Bulgaria
Hello again , I have found some more info
1.Stamped on the metal 14 digits it is : RN461fx4165729
2.Code Gravage : 4165729 - its like another barcode
3.I observed some kind of core stamped on the plastic part of the radio, but its too hard to see it .
4.I have pictured all the radio , so i can post some pics if its required
5.Thanks in advance
Username: Aria2
Hi,
Any help please!
Car radio code is needed.
Serial no:BE1150, R1014347.
I appreciate sincerely.
Username: Dekster
POLAND
Post Number: 389
Tara
Your code is : 23232
contact me:
http://koddoradia.pl/
e-mail: stefan15@poczta.onet.pl
I greet.
Post Number: 11486
biggie_3
Username: Biggie_3
RN461FX4165729 = code 3643
Username: Biggie_3
Varna, Bulgaria
Thanks for the support , now the f... radio should give me a chance to enter that code Thanks a lot , i hope it will work
