i come on this forum to search some advices from the Pros for my future install in my car. I'm French so sorry for the bad sentences or words please..
Its about the Voice.
What i search is simple and clear !
-=( Amazing Power and Quality )=-
---->> Power :
For the speakers, each Door of my car can take 1 * 200 mm and 2 * 165 mm speakers and 1 * 100 mm. (so 4 speakers by door)
for the power, i would like to have around -2 * 150 RMs,4 Ohms ( 165 mm) -1 * 350 RMs, 4 Ohms ( 200 mm). For the tweeters i already have the Audiopipe ATX-3720 150 rms, 4 Ohms. ( 100 mm)
Yes i search a Huge Power..
I'm interested by the Impact RH 6638 ( http://impactcaraudio.it/eng/products/components/rh-high-power/rh-6638 ) And for the 200 mm the Impact HS 8050 ( http://impactcaraudio.it/eng/products/components/hs-high-sensitivity/hs-8050 ) for the 100 mm well for the moment i keep them but maybe will change them to follow the quality, i dont know yet. What do you think ? Maybe you can advice me better than the Impact too.. My Budget: 4 * 165 mm 650 Euros MAx.. 2 * 200 mm 300 Euros MAx..
And of course need a good Amplifier to push easy this Power.
I already have 2 Amplifiers Audison LRx 2.5 (the blue version) 2 * 200Rms 4 ohms 2 * 330Rms 2 Ohms 1 * 660Rms 4 Ohms
But i would like to add an another Amplifier which will push more easy the 165 mm or the 20 mm i dont know yet i will read your advices for that because now 2 years i use the Lrx and now i need more Power in my voice.
Budget for the Amplifier hum.. lets say 650 - 700 Euros MAx.
--->> Quality :
Lets talk about the voice Quality.
for the speakers, i would like to have the best voice quality than possible i can have for the budget. That is why maybe you can advice me better than the Impact i have proposed or not.. but you need to remember i want to keep the power i asked too...
For the Amplifier.. If i take a new Amplifier it is for a Better Voice Quality too.. So, that will be good to have better than the Audison Lrx for the budget without forget the power of the speakers...
Well.. i try to have an Audiophile Voice Quality.
i saw some Amplifiers like - Boston Acoustics GT-2300 (http://www.ebay.com/itm/NEW-BOSTON-ACOUSTICS-GT2300-1400-WATT-RMS-2-CHANNEL-CAR-AMPLIFIER-/150952104779?pt=Car_Audio_Video&hash=item232572534b&vxp=mtr ) - Zapco DC752(http://www.ebay.com/itm/ZAPCO-DC750-2-2-CHANNEL-750W-RMS-MOSFET-SPEAKER-AMPLIFIER-W-DIGITAL-PROCESSING-/170949228754?pt=Car_Amplifiers&hash=item27cd5e38d2 ) im sure there are more amplifiers avalaible..
but i really dont know how is the voice Quality of them compared to my Audison i dont want to be disappointed about that. I let's the pros advice me to have what i try to search =)
For more informations, i have a 12 Volts Battery not more ! My batterie is a LifeLine GPL-8DA 255 AH ( http://www.lifelinebatteries.com/rvflyer.php?id=7 )
I already have an Audiopipe Subwoofer 1000 rms and a Kenwood excelon for the Bass Amplifier but for the moment i only work the voice quality. Bass Later. And for the End, i have an Alpine CDA - 9855R.
