New member Username: Collisa70
Post Number: 1 Registered: Oct-12
Posted on please can anyone help,,ive put the right code in my radio and i have no sound,,,any ideas,,,2006 renault scenic,,cheers |
Silver Member Username: Dekster
POLAND
Post Number: 290 Registered: Sep-12
Posted on Also quote the SECURITY NUMBER. This is found on a label on the metal casing in the format TOA123 or TA123 or just A123 at the end of a barcode If in doubt post ALL the letters+numbers on any labels or barcodes contact me: e-mail: stefan15@poczta.onet.pl I greet. |
Platinum Member Username: Regrooster
Post Number: 11422 Registered: Aug-08
Posted on If you are certain it is the correct code make sure you press the final button that stores the code ( ¬ or 6 or 5) for at least 10 seconds |
Post Number: 2 Registered: Oct-12
Posted on c285 rnrd0450183829 renrdw132-10 fd0805190183829 |
POLAND
Post Number: 291 Registered: Sep-12
Posted on Your code is :1794 contact me: e-mail: stefan15@poczta.onet.pl I greet. |
Post Number: 3 Registered: Oct-12
Posted on sure its the correct code,,dosent beep no more though when i hold 6 in,,,every ok,,like stations and everythingthing on dash comes up puzzled |
Post Number: 4 Registered: Oct-12
Posted on thanks dexter,,thats what ive put in,,,but theres no sound,,and it dosent beep when confirmned anymore |
Post Number: 5 Registered: Oct-12
Posted on everything works as it shud,,,theres just no sound at all,,,,any ideas |
Post Number: 11425 Registered: Aug-08
Posted on Turn the volume to maximum. If still no sound (hiss or anything ) then you have a problem with your speakers (wiring or connectors?) ...or the radio output circuit |
