Ford RDS 2006 keycode help!
Username: Juustomies
H Guys. Can anyone provide the keycode for a RDS2006 from my Transit which had a dead battery? The code (6838) in the handbook
doesn't work for some reason.. It displays the following serial at power up:
M814NOV
Life is miserable without my radio...
Username: Dekster
POLAND
Post Number: 288
post all numbers from radio
http://carradiohelppage.comlu.com/
contact me:
e-mail: stefan15@poczta.onet.pl
I greet.
HI Dekster
what other numbers? Do I have to pull the radio out of the dash then?
Username: Regrooster
Post Number: 11421
TLOZ
The radio SERIAL NUMBER is required for a code
It usually begins with M or V followed by SIX digits ...such as M654321 or V654321
Sometimes pressing buttons 6 & 1 together or 6 & 2 will display this number
Otherwise remove the radio from the dashboard and post the SERIAL NUMBER found on a label on the casing
OK Thanks. I made some tools to remove the radio and found the code written on the top of the unit. I 'll try tomorrow otherwise I'll post the serial.. So what is the code scrolling on the unit display (M814NOV ) for? Does this mean anything....
Cheers
Z
Need to Register?
Forgot Password?
Enable HTML code in message
