Platinum Member Username: Regrooster
Post Number: 11409 Registered: Aug-08
Posted on The code may be written on the radio or on a card in the glovebox (or similar "hidden" place ) Further suggestions may be found here http://www.youtube.com/watch?v=tgfRmBo7Pu0&feature=related Otherwise if you are in the USA try https://radio-navicode.honda.com/ https://www.ahm-ownerlink.com/login.asp?page=%2Fprod_home.asp If the above suggestions are not successful ,then unfortunately the code will not be available for free (or cheap ) from anywhere on the Internet. Will only be available from your Main HONDA Dealer or a Radio Decoding Service Useful HONDA Contacts https://radio-navicode.honda.com TELEPHONE NUMBERS Honda UK 0845 200 8000 Honda USA 1-800-999-1009 (Toll Free) Honda Canada 1-800-387-5399 (Toll Free) Honda Aus 1800 804 954 (Toll Free) Honda NZ 0800 2 46632 (Toll Free ==================================================== |
