Username: Soapster Post Number: 1 Registered: Oct-12
Thursday, October 18, 2012 - 01:16 GMT Hiya, I have just bought a sceond hand Renault Megane (2001) and the radio isn't working. I have all the numbers - Model no - 22DC259/62T Prod no - FD0501090288579 Bar code no - 7700434422TN110 If anyone could help me get a code that would be great :D Sophie
Username: Dekster POLAND
Post Number: 224 Registered: Sep-12
Thursday, October 18, 2012 - 05:36 GMT Code is: 2878 contact me: e-mail: stefan15@poczta.onet.pl I greet.
Username: Soapster Post Number: 2 Registered: Oct-12
Thursday, October 18, 2012 - 15:48 GMT Ah thank you Dekster! I will try that and see if it works! Would be nice to hav music again! Sophie
Username: Soapster Post Number: 3 Registered: Oct-12
Thursday, October 18, 2012 - 19:48 GMT Hey, just thought I'd let you know that it worked. Thank you so much!
Username: Chappers Post Number: 1 Registered: Oct-12
Sunday, October 28, 2012 - 09:26 GMT Hi there! I have a 2002 Renault Laguna and unfortunately the battery went flat. Now I need to enter the code but it isn't written in the book - can anybody help please? I'm not sure what numbers etc you need? Cheers Jamie
Post Number: 271 Registered: Sep-12
Sunday, October 28, 2012 - 09:31 GMT Jarnie post 14 or 15 digit number start on 7700 or 8200 quote the SECURITY NUMBER. This is found on a label on the metal casing in the format TOA123 or TA123 or just A123 at the end of a barcode http://www.davidsonelectronics.co.uk/serial_locate.htm contact me: e-mail: stefan15@poczta.onet.pl I greet.
Username: Chappers Post Number: 2 Registered: Oct-12
Sunday, October 28, 2012 - 16:23 GMT Hi Dekster, Many thanks for your response! The numbers are: T0P386 & 8200063200TP386 Thank you! Jamie
Post Number: 273 Registered: Sep-12
Sunday, October 28, 2012 - 16:27 GMT Your code is : 0637 contact me: e-mail: stefan15@poczta.onet.pl I greet.
Username: Chappers Post Number: 3 Registered: Oct-12
Sunday, October 28, 2012 - 16:29 GMT Thank you, much appreciated, I'll try it and let you know.
