Ford V Serial codes are not usually available for free from anywhere on the Internet (unless you can blag it for free from Ford) as they are not calculated using software but require access to the Ford factory database( via a Ford Dealer)...which is not commercially available as software.
See your PM message for cheapest options
Otherwise try your Ford Dealer or a Radio Decoding Service
