Renault Radio Code
Username: Strussh2012
Could anyone help with a radio code for Renault scenic 1999 model?
I bought a ranault and the radio requires a code for it to operate.
Many thanks in advance!
Username: Regrooster
Post Number: 11344
Sorry.......this is insufficient information
The radio has to be removed from the dashboard
Then quote the 14 character SERIAL NUMBER beginning with
RN* * * * * * * * * * * * found stamped in the metal casing.
Also quote the SECURITY NUMBER. This is found on a label on the metal casing in the format TOA123 or TA123 or just A123 at the end of a barcode
If in doubt post ALL the letters+numbers on any labels or barcodes
