Code for VW
Username: Cr125honda
Need a code for a factory VW radio.
Serial Number VWZ4Z7X5031636
Purchased on eBay to replace radio in daughters car with bad LCD display
Thanks, Ken
Username: Regrooster
Post Number: 11299
Sorry....will only be available from the Main Dealer or the unit will have to be taken into a Radio Decoding Service to obtain this code
It will not be available for free or cheap from anywhere on the Internet
Thanks Rooster.
Saw other listings with similar S/N's and was hoping mine wasn't one that needed to be taken in.
Hopefully my local VW dealership will do it at no or minimal cost.
It's what I get for trying to see if I could repair the display. The black plastic cover on the old radio was very brittle. Crumbled in little pieces when I removed it. I'd just use the faceplate off the new radio but unfortunately it's a little different (98 vs 01).
Thanks, Ken
