Username: Specksy79 Post Number: 1 Registered: Sep-12
Friday, September 14, 2012 - 20:18 GMT ive just bought a second hand opel, the stereo is on safe, there is no code written in the manual etc, i have no specialsit tools to take out the stereo to find the serial number, is there any way to get the code?
Username: Regrooster Post Number: 11246 Registered: Aug-08
Friday, September 14, 2012 - 23:16 GMT no The correct radio SERIAL NUMBER is required for a code First remove the radio from the dashboard. Then post the radio make+model plus all the letters+numbers on any labels,barcodes and a 14 character Serial Number stamped in the metal casing. This information can then be used to see if a code can be calculated
Username: Specksy79 Post Number: 2 Registered: Sep-12
Saturday, September 15, 2012 - 00:38 GMT Ok, friend maybe able to get stereo out tomorrow! Will get back to you 'pleading' for the code!! Thanks
Username: Specksy79 Post Number: 3 Registered: Sep-12
Saturday, September 15, 2012 - 12:58 GMT (on top of stereo -sticker) GM SIEMENS VDO 330886636 No: 24 469 305 Type: CDR2005 (E) UY8 (stamped onto the side) GM020553715155
Username: Specksy79 Post Number: 4 Registered: Sep-12
Saturday, September 15, 2012 - 13:00 GMT Sorry missed the bar code! A2C53057679 BS0005443715155
Username: Regrooster Post Number: 11249 Registered: Aug-08
Saturday, September 15, 2012 - 17:17 GMT Sorry....will only be available from the Main Dealer or the unit will have to be taken into a Radio Decoding Service to obtain this code It will not be available for free or cheap from anywhere on the Internet
Username: Specksy79 Post Number: 5 Registered: Sep-12
Saturday, September 15, 2012 - 17:29 GMT ok , thanks for getting back to me
Username: Ruby310 Post Number: 1 Registered: Oct-12
Wednesday, October 03, 2012 - 16:46 GMT I changed my battery on my OPEL AGILA 1.2 (Elegance) year 2001 (06/06/2001). Autoradio and CD player dont work anymore. And I lost my safe code... Can you help me, please. I can give you other informations... Thanks for getting back to me
Username: Dekster POLAND
Post Number: 131 Registered: Sep-12
Wednesday, October 03, 2012 - 16:55 GMT Savornin Enter all numbers from radio contact me: e-mail: stefan15@poczta.onet.pl I greet.
