I have a 2006 Mercedes Benz ML350 with the original radio. I had to replace the battery and now need the audio code for the radio. VIN# is 4JGBB86E76A001262. Can you help me retrieve the code please? Thank you a ton!
if this does not work then it will only be available from the Main Dealer or the unit will have to be taken into a Radio Decoding Service to obtain this code
It will not be available for free or cheap from anywhere on the Internet
