Hancas Alex New member Username: Alexhancas i have a 6000cd Ford. Serial No. V078340
Ford V Serial codes are not usually available for free from anywhere on the Internet (unless you can blag it for free from Ford) as access is required to the Ford factory database( via a Ford Dealer)...which is not commercially available as software.
See your PM message for cheapest options
Otherwise try your Ford Dealer or a Radio Decoding Service
