BMW Code
Username: Noelnoel
I replaced the battery on my wife's BMW and the code in the glovebox doesn't unlock the radio.... it is a 5-digit code (11464), and I was sure that several years ago, the code I put in was only 4 digits. The info on the radio is:
BP0263 18403844
FD291 Index 49
7 640 263 342/40/44/46
Many thanks in advance.
Username: Regrooster
Post Number: 11105
The 5 digit code is for USA radio station tuning
The 4 digit code is for UK/Europe tuning
Try code 3844
Username: Noelnoel
Thank you. I must have been misinformed... I was told the 4-digit code was for radios marketed to UK and the 5 was for the ones marketed to the USA.
Is the 5-digit code I had (11464) correct? If so, something must be broken since I've tried it and the radio just locks for an hour or so before I can try again.
Post Number: 11114
Read my answer again as that is what I quoted
UK/Europe = 4 digit code
USA = 5 Digit code
The 5 digit code is not in my database as it requires the scarce US Blaupunkt Calculator .
Try mailing
restoredclassic@aol.com
to see if they can help
Mention this forum
Username: Bigdish2003
Hi,
Can you help me find a code for a BMW e36business radio with
Sn# ph7850v1222058
Thanks in advance
Username: Elektron1234
Poland
Post Number: 449
Mike
code is 8716
contact me:
e-mail-stanislawgoclon@o2.pl
Username: Ivan26
Tomislavgrad
I need the radiocode for my blaupunkt bmw reverse rds 6512 - 8 375 665 BP6262 V 7055381 FD217 INDEX D 7 646 262 040/041
Username: Dekster
Bytom
Post Number: 17
Code is: 5551
contact me:
e-mail: stefan15@poczta.onet.pl
I greet.
