Need help with my car audio code please
Username: Femi16
Hi,
I changed my battery for a new one and since then, the audio keeps asking for a code. The car is Rover 45 and the Audio manufactured by Philips.
Model number: 22DC594/60B
Production number: 0600051132753
Is any other detail required for the Audio? Any help will be very much appreciated. Regards.
Username: Regrooster
Post Number: 11042
Post the 14 character Serial Number RGxxxxxxxxxxxx found stamped in the metal casing
Username: Femi16
Thanks Reg Rooster for the reply.
The serial number is RG599EY1132753
Post Number: 11047
Username: Femi16
RG599EY1132753
Sorry....will only be available from the Main Dealer or the unit will have to be taken into a Radio Decoding Service to obtain this code
It will not be available for free or cheap from anywhere on the Internet
Username: Femi16
Thank you for your advice.
Username: Femi16
The serial number I actually provided was an error from my side - sorry for this. I cross checked it and I discovered that it was wrong. The correct serial number is RG594FY1132753
I will appreciate it if you can still help.
Post Number: 11220
femi16
Username: Femi16
RG594FY1132753
Username: Femi16
www.mgrovercodes.com has provided me the code and it is done now. Thanks for your concern on this forum.
