Peugeot 106 Phillips radio unlock code
Username: Gavgaz
Hi everyone,
my 106 has had its battery replaced and now the radio is asking for a code, does anyone know what it might be?
Model No: 2 2 R C 2 0 0 / 6 5
Prod No: F D 1 0 0 1 2 5 9 3 2 7 3 7 3
Thanks
Username: Regrooster
Post Number: 11189
The correct radio SERIAL NUMBER is required for a code
First remove the radio from the dashboard.
Then post the radio make+model plus all the letters+numbers on any labels,barcodes and a 14 character Serial Number stamped in the metal casing.
This information can then be used to see if a code can be calculated
