Hi All I am not having a lot of luck with my radio code after it was disconnected. I have already paid twice from two different people who came back with the same code (4481) which does not work. I am now stuck as the book says 5853. Info as follows Model No. 22DC278/62B TOV559 RN278F10004407 FD0101170004407
Hope this is all the info you need. I'm soo fed up of no radio in the car
if you have any skill with electronics will be possible yes, you will need to set up a reader in order to read the eepron eepron your radio if you have experience with electronics will not be difficult, but if you have not, I suggest that you bring to some friend that can help you.
Hi Reg Rooster Thanks for this but I have tried this code and it doesn't work. I have had this code from 4 different people now so I think at some point the radio has been repaired and they have managed to change the code. I spoke with Renault and they were worse than useless. I have been told it will cost £40 to have the code deleted and a new one added :-( Any ideas??
