Radio code Bmw
Username: Clline
Bonsoir,
Can anyone help to find the code for BMW Business cd RDS.
Serial No:v9702434
Merci
Username: Regrooster
Post Number: 11003
BMW do not make radios .They only affix their badge onto radios made by the large manufacturers (ALPINE , BLAUPUNKT etc).
In order to attempt to calculate your code , the radio will have to be identified which normally means it has to be removed from the dashboard
Then please supply your radio MAKE+MODEL plus ALL the NUMBERS+LETTERS on ANY LABELS , BARCODES or STAMPED IN THE METAL CASING
Username: Clline
The only numbers i have:
-Typ/model: BP3850
-Serial number::v9702434
-Safety-Nr:8647
Thanks for your help
Post Number: 11007
try code 8647
