New member Username: Dkorem
Post Number: 1 Registered: Aug-12
Posted on Hi, Need a code for my radio: BP7649378316 Product no. FIAT: 735293234 Thank you for you kind support and reply Dave |
Platinum Member Username: Regrooster
Post Number: 10994 Registered: Aug-08
Posted on Post the 14 character Serial Number beginning BPxxxxxxxxxxxx found stamped in the metal casing |
Post Number: 2 Registered: Aug-12
Posted on the 14 digits code: BP 937 817 286681 Thanks againg. you're quick and kind !! |
Post Number: 10995 Registered: Aug-08
Posted on try code 4656 |
