New member Username: 21ajjcMerseyside, 07514165104 United Kingdom Post Number: 3 Registered: Nov-11 | Hi can anyone help me with my renault radio code model no : renrdw133-10 rnrd0540068951 prod no : fd0604340068951 bar code 8200300860tk987 8200 300 860 --b many thanks in anticipation John |
Platinum Member Username: RegroosterPost Number: 10297 Registered: Aug-08 | Duplicate post....Already answered Please do NOT post the SAME request in more than ONE thread It is not necessary....and can cause confusion |
New member Username: BouamPost Number: 3 Registered: Jan-12 | Can you help please, it is a Renault TUNERLIST radio Model: renrdw100-10 security code: R547 Many thanks |
Platinum Member Username: RegroosterPost Number: 10307 Registered: Aug-08 | bouam New member Username: Bouam Post Number: 3 Registered: Jan-12 Bouam posted on Wednesday, May 02, 2012 - 14:15 GMT Can you help please, it is a Renault TUNERLIST radio Model: renrdw100-10 security code: R547 Many thanks ===================================== ===================================================== Reminder :..NO MULTIPLE CODE REQUESTS ON THIS FORUM Single free code request for personal use only (one code request every 6 months minimum) This is for security reasons in order to prevent abuse by traders+dealers, car radio thieves and other chancers Sorry if you are one of the honest ones ! ==================================================== |
New member Username: TerrytPost Number: 1 Registered: May-12 | Hi! Changed my battery now need a code for my 55 clio the numbers i have are ;RNRD3450199917 RENDW220-00 FD0505266199917 8200409475 8200409475T can anyone help please? Many Thanks |
Platinum Member Username: RegroosterPost Number: 10316 Registered: Aug-08 | terry thomas RENAULT ===================================== Also quote the SECURITY NUMBER. This is found on a label on the metal casing in the format TOA123 or TA123 or just A123 at the end of a barcode If in doubt post ALL the letters+numbers on any labels or barcodes |
New member Username: Garn1cPost Number: 1 Registered: Jun-12 | Hi Battery died on the weekend and I'm looking for the radio code. Can someone please help? MODEL: 22DC278/62P PROD : FD0203040189217 SERIAL: 8200152346TK622 TOK622 RN278F30189217 8200 152 346 --B Thanks very much. |
New member Username: MichalaPost Number: 1 Registered: Jun-12 | hello same problem as above battery died and cant find code please help my model no 22dc277/62 tou932 rn277f30094873 prod no fd0103020094873 82002561417tu932 thanks for any help |
New member Username: Neosse76Post Number: 1 Registered: Jun-12 | Hi to all, same problem as above battery died and cant find code My car is: renault scenic Code find on the radio side: RNRD4150005968 RENRDW232-10 FD0305270005968 thanks for any help |
New member Username: BouamPost Number: 5 Registered: Jan-12 | for reme, try 5078 |
New member Username: Cbx1000zPost Number: 1 Registered: Jun-12 | HI All, I require a Philips radio code for a renault laguna (52reg) which i have just bought and it has had a new battery fitted on it and the owner did not know the code. TOQ342 RN279F20355653 Thanks a million if anyone can help Cheers Mike |
Platinum Member Username: RegroosterPost Number: 10433 Registered: Aug-08 | Username: Cbx1000z try code 9653 |
Platinum Member Username: RegroosterPost Number: 10434 Registered: Aug-08 | re: Neos RENAULT ----------------------------- Also quote the SECURITY NUMBER. This is found on a label on the metal casing in the format TOA123 or TA123 or just A123 at the end of a barcode If in doubt post ALL the letters+numbers on any labels or barcodes |
Platinum Member Username: RegroosterPost Number: 10435 Registered: Aug-08 | Garn1c RENAULT Try code 4769 |
New member Username: Neosse76Post Number: 2 Registered: Jun-12 | Thanks for your reply. This is security number is: S611-security barcode is:8200367492T [S611-security] |
New member Username: Cbx1000zPost Number: 2 Registered: Jun-12 | Regrooster, Thanks very much, works a charm. Now have sounds. Cbx1000z |
New member Username: Garn1cPost Number: 2 Registered: Jun-12 | @Reg Rooster Thanks very much, worked a treat. Awesomesauce!! |
New member Username: RikbPost Number: 1 Registered: Jun-12 | Hi, could you please help with a code for my cd player (Tuner List) in my Scenic (Sept 2002), which has just had its battery replaced? Model: RENRDW131-10 RNRD0340131194 PROD No: FD0404160131194 Serial: 8200300858TH713 Security Number: H713 Many thanx in advance ;-) |
New member Username: Garn1cPost Number: 3 Registered: Jun-12 | @rikb Try code 2803 |
New member Username: MichalaPost Number: 2 Registered: Jun-12 | thank great work |
New member Username: Neosse76Post Number: 3 Registered: Jun-12 | Nobody has news? Repeat my code: Renault Scenic 2006 RNRD4150005968 RENRDW232-10 FD0305270005968 barcode is: 8200367492T [S611-security] Thanks |
Silver Member Username: Elektron1234Poland Post Number: 311 Registered: Jan-12 | Neos code is 7397 contact me: e-mail-stanislawgoclon@o2.pl |
New member Username: Neosse76Post Number: 4 Registered: Jun-12 | @elektron1234 Many thanks, work perfectly. Great work! |
New member Username: RikbPost Number: 2 Registered: Jun-12 | @ garn1c Thanks very much - worked perfectly - now I don't have to endure a quiet 5½ hour drive to Newcastle! |
New member Username: NeeyeePost Number: 1 Registered: Jun-12 | Hello I have a Renault Scenic and don't have the code for the radio. Can anyone help, please? I hope these information will help? Model RENRDW332-10 RNRDBP60007192 Prod No: FD0006220007192 Bar Code: 8200633636T |
New member Username: NeeyeePost Number: 2 Registered: Jun-12 | Sorry my earlier information seems incomplete Repeat my code: Renault Scenic 2006 RNRDBP60007192 RENRDW332-10 FD0006220007192 barcode is: 8200633636T [S936-security] |
Platinum Member Username: RegroosterPost Number: 10464 Registered: Aug-08 | Username: Neeyee try code 7057 |
New member Username: GabesdadPost Number: 1 Registered: Jun-12 | Hi there, battery died on Renault Clio, and the code someone scribbled in the manual doesn't work... please can you help? Here are the numbers: Model No: 22DC259/62F Prod No: FD0200120098098 Other numbers from the sticker: TOW186 RN259FY0098098 8200029539TW186 8200 029 539 Number from back metal casing: 029021 There is also a box etched above that number which contains a circle with a horizontal line through it and the number 2. Many thanks in advance for any help you can give. ATB, Andrew |
New member Username: GabesdadPost Number: 2 Registered: Jun-12 | Hi there, battery died on Renault Clio, and the code someone scribbled in the manual doesn't work... please can you help? Here are the numbers: Model No: 22DC259/62F Prod No: FD0200120098098 Other numbers from the sticker: TOW186 RN259FY0098098 8200029539TW186 8200 029 539 Number from back metal casing: 029021 There is also a box etched above that number which contains a circle with a horizontal line through it and the number 2. Many thanks in advance for any help you can give. ATB, Andrew |
New member Username: GabesdadPost Number: 3 Registered: Jun-12 | Oops, sorry for the double post... |
New member Username: Chummy400Post Number: 1 Registered: Jun-12 | hi, can anybody help get my radio back on, needs a code number. renault scenic 1998 here are all the nubers on the sticker as i dont know whats required RN481FX9112425 FD 06 99 10 9112425 MODEL NO. 22DC481/62 7700 433 070 H429 AND SOMEONES WRITEN IN INK J198 THANKS |
New member Username: NeeyeePost Number: 3 Registered: Jun-12 | Thanks so much, the radio is now back to life |
Platinum Member Username: RegroosterPost Number: 10501 Registered: Aug-08 | Username: Chummy400 Try code 3712 |
Platinum Member Username: RegroosterPost Number: 10502 Registered: Aug-08 | Username: Gabesdad Try code 3894 |
New member Username: Msarron30Post Number: 2 Registered: Jun-12 | need code for my radio..radio serial number - RN277F30251182 PHILIPS SERIAL NUMBER 8200256141TW768 Thankyou |
New member Username: Jp07Post Number: 1 Registered: Jun-12 | Can you help me?? I need a code for my Laguna, info from the radio is as follows.... model number 22dc279/62z, productnumber fd0202370355332 toj265, rn279f2035532, serial 8200002607tj265. Thank you |
New member Username: LozasPost Number: 4 Registered: Dec-11 | Hello, i need a code for my Scenic Model no:22DC259/62P Prod No:FD0401060228478 TOQ714 RN259F10228478 bar code 7700434424TQ714 Thank you |
Platinum Member Username: RegroosterPost Number: 10507 Registered: Aug-08 | Username: Lozas try code 9276 |
Platinum Member Username: RegroosterPost Number: 10508 Registered: Aug-08 | re: JohnP RENAULT --------------------------- Try code 7599 |
Platinum Member Username: RegroosterPost Number: 10509 Registered: Aug-08 | arron New member Username: Msarron30 Post Number: 2 Registered: Jun-12 Msarron30 posted on Monday, June 18, 2012 - 15:05 GMT need code for my radio..radio serial number - RN277F30251182 PHILIPS SERIAL NUMBER 8200256141TW768 Thankyou ======================================= Duplicate post....Already answered Please do NOT post the SAME request in more than ONE thread It is not necessary....and can cause confusion |
New member Username: TanfasticPost Number: 1 Registered: Jun-12 | please can you give me the radio code for my renault megane rx4 the numbers on my radio are 22DC259/62R TO 2665 RN259FY0011506 FD0400450011506 7700434426TZ665 Thank you |
New member Username: RabdacPost Number: 1 Registered: Jun-12 | hi please can you help me with my renault clio the battery died and now i have no radio thank you renault radiosat 6000 7700433080 phillips 22dc481/62 fd 1299349241723 model no. 22dc481/62 is there anything else you need? thank you! |
Platinum Member Username: RegroosterPost Number: 10528 Registered: Aug-08 | Username: Tanfastic try code 0374 |
Platinum Member Username: RegroosterPost Number: 10529 Registered: Aug-08 | Username: Rabdac RENAULT ========================================= Sorry.......this is insufficient information The radio has to be removed from the dashboard Then quote the 14 character SERIAL NUMBER beginning with RN* * * * * * * * * * * * found stamped in the metal casing. Also quote the SECURITY NUMBER. This is found on a label on the metal casing in the format TOA123 or TA123 or just A123 at the end of a barcode If in doubt post ALL the letters+numbers on any labels or barcodes |
New member Username: Moose123Post Number: 1 Registered: Jun-12 | Hey nedd some help with the code after detatching my battery. model no: 22DC279/62P prodnr: FD0301450326260 TOE956 RN279F10326260 7700434425 Thanx in advance |
New member Username: RabdacPost Number: 2 Registered: Jun-12 | hi guys hi please can you help me with my renault clio the battery died and now i have no radio thank you renault radiosat 6000 7700433080 phillips 22dc481/62 fd 1299349241723 model no. 22dc481/62 is there anything else you need? thank you! that is my previous post the new information is RN 481FX9241723 and the bar code is 7700 433 070 V852 |
Platinum Member Username: RegroosterPost Number: 10539 Registered: Aug-08 | Username: Rabdac try code 4109 |
Platinum Member Username: RegroosterPost Number: 10540 Registered: Aug-08 | Username: Moose123 try code 1453 |
New member Username: PlavkePost Number: 1 Registered: Jun-12 | Hi, please can you give me the radio code for my renault megane II 2003 Mod. no- 22DC277/62 T009 Security RN 277F40624970 Prod. no - FD0704350624970 Bar code 8200256141TT009 Thanx in advance |
Silver Member Username: Elektron1234Poland Post Number: 326 Registered: Jan-12 | plavke code is 6939 contact me: e-mail-stanislawgoclon@o2.pl My PayPal ID is stanislawgoclon@o2.pl |
New member Username: B00dzPost Number: 1 Registered: Jun-12 | hello, Model No: 22DC77 / 62 PROD No: FD0103270230175 RN277F30230175 8200256141TW718 8200 256 141 --c T0W718 Renault Megane 2004 Help Much Appreciated |
Platinum Member Username: RegroosterPost Number: 10546 Registered: Aug-08 | Username: B00dz try code 3251 |
New member Username: Lapin22Post Number: 1 Registered: Jun-12 | Good evening Please generate me a code Model No: 22DC 257 / 62 PROD No: FD0404170099054 RN257F40099054 8200256140TS403 8200 256 140 --D Renault Megane 2004 Thank you |
Platinum Member Username: RegroosterPost Number: 10550 Registered: Aug-08 | Username: Lapin22 try code 7590 |
New member Username: Lapin22Post Number: 2 Registered: Jun-12 | Thanks you very much. code is OK |
New member Username: PietuPost Number: 1 Registered: Jun-12 | My radio stopped working after battery change. I didn't find code for radio. Could you help me with this issue? Model No: RENRDW100-10 Serial Code(): 8200247962TK766 Security Code: TOK766 |
New member Username: Jamesw007Post Number: 1 Registered: Jun-12 | Hi After changing my battery I cant find my code my model no 22DC277/62 TG968 RN277F30359838 FD0303480359838 Thanks for any help |
New member Username: B00dzPost Number: 2 Registered: Jun-12 | Thank you Regrooster, the code worked fine ! |
New member Username: Frank00000Post Number: 1 Registered: Jun-12 | Help me please with a code for :![]() Thanks! Frank00000 |
Platinum Member Username: RegroosterPost Number: 10570 Registered: Aug-08 | Username: Pietu Try code 4511 |
Platinum Member Username: RegroosterPost Number: 10571 Registered: Aug-08 | Username: Jamesw007 RENAULT Try code 5295 |
Platinum Member Username: RegroosterPost Number: 10572 Registered: Aug-08 | Username: Frank00000 RENAULT Try code 4693 |
New member Username: StarbugDublin, Dublin Ireland Post Number: 1 Registered: Jun-12 | Hi I bought a 96 Megane at the weekend, and I need the radio code (Previous owner never bothered to get it) I rang the Renault dealer, and they said I needed the chassis number, but I couldn't find it. They said I could bring it in but it would cost 20. Anyway, the only serial number I could find on it when I pulled it out was RN594FT1023847 There aren't really any labels on it, only the abouve number which is stamped/engraved on the side It's a Phillips Radio btw Thanks in advance for any help Dave |
Silver Member Username: Elektron1234Poland Post Number: 337 Registered: Jan-12 | dave \code is 6382 contact me: e-mail-stanislawgoclon@o2.pl My PayPal ID is stanislawgoclon@o2.pl |
New member Username: Robo23Post Number: 1 Registered: Jun-12 | Help me please with a code for : A 42 AL R92S 51289 SW 1.00 MW 1.201 020366 8200 318 360 -- B PN MH9RN920LC 04 21 54C03235K14 - 0 S/No. ALR92S40551289 T40 551 289 8200 089 153T R929 8200 339 742 MODEL NO: RENMCC101-00 INDUS VDO: 0495027100276780 PROD No: FD0004280017170 |
New member Username: DarkervinPost Number: 10 Registered: Sep-10 | Help me please with a code for : Model No: RENRDW240-10 PROD No: FD0306120125603 RNRD7660125603 8200505114T L810 SECURITY Thanks ! Renault Megane 2006 |
Platinum Member Username: RegroosterPost Number: 10590 Registered: Aug-08 | Username: Robo23 Sorry....will only be available from the Main Dealer or the unit will have to be taken into a Radio Decoding Service to obtain this code It will not be available for free or cheap from anywhere on the Internet |
Platinum Member Username: RegroosterPost Number: 10591 Registered: Aug-08 | Username: Darkervin try code 2369 |
New member Username: Nathanfitz03Post Number: 1 Registered: Jul-12 | hello can sombody please help me car battery went flat! now have no radio can somebody please help me with the unlock code thanks model no 22DC279/62Z TOR048 RN279F20212327 PROD NO FD020204021237 8200002607TR048 8200 002 607 --C thats everything that i can see thaks for any help given!! |
New member Username: FfeeKlaipeda, Klaipeda Lithuania Post Number: 1 Registered: Jul-12 | Renault Scenic 1998 9022 214 81629 Model No. 22DC481/62 Prod. No. FD 1299389268456 Bar Code 7700 433 070 W029 Code Gravage (Security code?) 9268456 ![]() |
New member Username: Timbo10Post Number: 1 Registered: Jul-12 | Hi had some work carried out by a Garage on my second hand 2006 Scenic and they disconnected the battery. Checked all my paper work but can not find the radio code can anyone please assist. Details are RNRD7660061965 RENRDW240-10 FD0306010061965 8200505114T D589 If anymore detail is required please let me know. Any help will be very much appreciated. |
New member Username: Lee020202Post Number: 1 Registered: Jul-12 | hi, i have had some garage work done on my 2002 scenic and it has come back needing radio code model no - 22DC258/6P TOX368 RN258F20027258 PROD NO - FD0002110027258 if anyone knows the code or where i can get the code it would be a big help thank you |
New member Username: SpedePost Number: 1 Registered: Jul-12 | Hi dear code kings, my Renault Clio, 2001 is missing code. Model: 22DC279/62F TOW132 RN279F10132633 Prod no: FD0301080132633 Code would be nice to have. |
Platinum Member Username: RegroosterPost Number: 10638 Registered: Aug-08 | Username: Ffee try code 3934 |
Platinum Member Username: RegroosterPost Number: 10639 Registered: Aug-08 | Username: Nathanfitz03 try code 8962 |
Platinum Member Username: RegroosterPost Number: 10640 Registered: Aug-08 | Username: Timbo10 Try code 1486 |
Platinum Member Username: RegroosterPost Number: 10641 Registered: Aug-08 | Username: Lee020202 Try code 2670 |
Platinum Member Username: RegroosterPost Number: 10642 Registered: Aug-08 | Username: Spede Try code 3817 |
New member Username: FfeeKlaipeda, Klaipeda Lithuania Post Number: 2 Registered: Jul-12 | Yes, that was the one. Thank You very very very much! |
New member Username: Timbo10Post Number: 2 Registered: Jul-12 | Hi Reg Rooster you are the man code worked. Really appreciate your help Many thanks Timbo10 |
New member Username: SpedePost Number: 2 Registered: Jul-12 | Hi Reg Rooster, code was correct, also got same from local Renault dealer! Many thanks anyway! Spede |
New member Username: Mumof3Post Number: 1 Registered: Jul-12 | Hi, please can you tell me the security code for my renault stereo. The precode is W232. Kind regards Samantha |
Silver Member Username: BogegeBG Post Number: 463 Registered: Dec-10 | Mumof3 try code 3787 |
New member Username: Mumof3Post Number: 2 Registered: Jul-12 | Thank you so much. 3 very happy kids again!! |
New member Username: Mickey_dPost Number: 1 Registered: Jul-12 | Hi, I'm looking for help with a code for a renault radio. 22DC279/62. Security Q728. Serial Number RN279F50472832. Thanks in advance. Michael. |
Silver Member Username: Elektron1234Poland Post Number: 348 Registered: Jan-12 | michael dockery code is 9256 contact me: e-mail-stanislawgoclon@o2.pl |
New member Username: BizzydPost Number: 1 Registered: Jul-12 | HI ALL. NEED A CODE FOR MY RENAULT MEGANE CAR CD PLAYER.. NOT TOO SURE WHAT TO LOOK FOR SO WILL PUT SOME DETAILS HERE IF NEEDED. I TRIED TO ATTACH A PIC BUT KEEPS SAYING "Your uploaded image exceeded the maximum dimensions of 620 x 600. Please shrink your image to be smaller than these dimensions"... DONT KNOW HOW TO "SHRINK" MY IMAGE =/ THANKS IN ADVANCE. Philips 22DC479/62 9022 214 79629 FD0898249053459 9053459 MODEL NO: 22DC479/62 PRODUCT NUMBER: FD0898249053459 BARCODE NUMBER: 7700 426 484 X970.. ON RIGHT SIDE OF THE RADIO IS HAS WHITE STICKER SAYING "M/CH 053516" - IF THIS MEANS ANYTHING |
New member Username: BizzydPost Number: 2 Registered: Jul-12 | RIGHT FINALLY GOT PIC UP IF HELPS?![]() |
Bronze Member Username: AymantnPost Number: 28 Registered: Dec-09 | Hi all This is the simplist method to recover you renault car radio code instantly and for free, just take a look at this video tutorial or visit this car radio decoding site: http://car-radio-unlock.blogspot.com/ |
Platinum Member Username: RegroosterPost Number: 10703 Registered: Aug-08 | Username: Bizzyd Try code 2036 |
New member Username: BizzydPost Number: 3 Registered: Jul-12 | thankyou very much reg rooster! code worked!! =] If the radio asks for code in future will it be same code or different? Thanks again in advance =] |
Platinum Member Username: RegroosterPost Number: 10725 Registered: Aug-08 | Username: Bizzyd the radio always uses the same code |
New member Username: ThegreenninjaPost Number: 1 Registered: Jul-12 | Hi, Looking for the code for my renault radio Product no fd0202020112759 Model no: 22dc278/62b security code x312. Would be amazing if i could finally get the radio back Thanks |
Platinum Member Username: RegroosterPost Number: 10735 Registered: Aug-08 | Username: Thegreenninja Try code 2651 |
New member Username: Riyaz_ktmPost Number: 1 Registered: Jul-12 | Hi there could you please help me getting the code for my sweet yellow Renault Megane Exapression convertible 2002. Which was Manufactured on : 01/02 Body type: 2D Cabriolet If you need any more details please let me know. Many many thanx .... |
Platinum Member Username: RegroosterPost Number: 10796 Registered: Aug-08 | Username: Riyaz_ktm Sorry.......this is insufficient information The radio has to be removed from the dashboard Then quote the 14 character SERIAL NUMBER beginning with RN* * * * * * * * * * * * found stamped in the metal casing. Also quote the SECURITY NUMBER. This is found on a label on the metal casing in the format TOA123 or TA123 or just A123 at the end of a barcode |
New member Username: Riyaz_ktmPost Number: 2 Registered: Jul-12 | okey.....model no:22DC279/62T product no:FDO301390139507 TOR115 thx alot |
New member Username: SemprontoPost Number: 1 Registered: Jul-12 | Hi everybody. My Renault Grand Scenic suddenly says "SPEECH" on the display. So I reset it, but I sadly discovered not to have the security code to reactivate. Can you kindly help me please? MODEL NO: RENRDW133-10 SECURITY: A785 RNRD0540038580 PROD NO: FD0204080038580 Thanks in advice. |
New member Username: Riyaz_ktmPost Number: 3 Registered: Jul-12 | sorry im giving some more info..to you model no:22dc279/62t TOR 115 RN279F10139507 prod no:fd0301390139507 7700434423TR115 7700434423....renault megane 2002 thx aot |
Silver Member Username: Elektron1234Poland Post Number: 368 Registered: Jan-12 | iyaz code is 8820 contact me: e-mail-stanislawgoclon@o2.pl |
Platinum Member Username: RegroosterPost Number: 10823 Registered: Aug-08 | Username: Sempronto Try code 0044 |
New member Username: Lisichka29Post Number: 1 Registered: Jul-12 | Hi, I've got the same problem with my radio here is the Prod No: FD0400450188101. Pleace someone help me. Thanx in advance. |
Platinum Member Username: RegroosterPost Number: 10830 Registered: Aug-08 | Username: Lisichka29 Sorry.......this is insufficient information The radio has to be removed from the dashboard Then quote the 14 character SERIAL NUMBER beginning with RN* * * * * * * * * * * * found stamped in the metal casing. Also quote the SECURITY NUMBER. This is found on a label on the metal casing in the format TOA123 or TA123 or just A123 at the end of a barcode If in doubt post ALL the letters+numbers on any labels or barcodes |
New member Username: SaltwarehouseSingapore Post Number: 1 Registered: Jul-12 | Help me, Reg Rooster! Just changed my Renault Kangoo air con compressor and my radio is locked. Model No. 22DC279/62 TOL 773 RN 279F30248889 Prod No. FD0603390248889 7700433948 TL 773 7700433948 --E Thanks in advance! |
Platinum Member Username: RegroosterPost Number: 10843 Registered: Aug-08 | Username: Saltwarehouse Try code 2503 |
New member Username: Lisichka29Post Number: 2 Registered: Jul-12 | Username: Regrooster Thank you very much but I already have the code |
New member Username: MonsefPost Number: 7 Registered: Jul-12 | BMW BLAUPUNKT BAVARIA C II BP9455 7 649 455 040 BP9455A2569889 |
Platinum Member Username: RegroosterPost Number: 10847 Registered: Aug-08 | New member Username: Monsef BE PATIENT !! MULTIPLE posts....ARE IGNORED Please do NOT flood the forum with the SAME request in more than ONE thread It is not necessary....and can cause confusion If you are in a rush then try an online Decoding service where you will get a reply straightaway....for a fee ! |
New member Username: SaltwarehouseSingapore Post Number: 2 Registered: Jul-12 | Reg Rooster the code works! You're the BOSS! THANK YOU SO MUCH!! |
New member Username: MonsefLibya Post Number: 10 Registered: Jul-12 | I want a Web site is free to open the car code |
New member Username: MdvPost Number: 7 Registered: Jul-12 | Hi i have one renault megane classic with one radio philipS. And i want know , if you can help me find my code with 4 digits. Renault 276 7700 433 946 --- 22DC461/62T 9022 214 61626 PA4Bis, 4*15, RDS FD 09 99 04 6022245 MODEL NO: 22DC461/62T PROD NO: 0999046022245 BAR CODE: 7700 433 946 V168 CODE GRAVAGE 6022245 thanks for spend a lot of time with me Best regards Marco |
Platinum Member Username: RegroosterPost Number: 10867 Registered: Aug-08 | Username: Mdv MULTIPLE POSTING IS TREATED AS SPAM AND IS IGNORED Please do NOT flood the forum with the SAME request . It is not necessary....and can cause confusion |
New member Username: DavedustPost Number: 1 Registered: Aug-12 | Hi, same problem has everyone here : battery changed, and no pin code provided by previous owner Model Number : 22DC278/62B T0R788 RN278F10004562 Prod Number : FD0101170004562 8200057681TR788 8200 057 681 --A Precode calculator gives 8255 which does not work Thank for help, Dave. |
New member Username: DimitriyPost Number: 1 Registered: Aug-12 | hello please help me find the code Renault Scenic 1998 Philips 22DC459/62L 902221459624 FD0798104078968 code gravage 4078968 7700426412F627 code routage 902221459624 RN459FW4078968 thanks |
Silver Member Username: Elektron1234Poland Post Number: 399 Registered: Jan-12 | Dimitriy code is 3518 contact me: e-mail-stanislawgoclon@o2.pl |
Platinum Member Username: RegroosterPost Number: 10985 Registered: Aug-08 | New member Username: Davedust Try code 5133 |
New member Username: DavedustPost Number: 2 Registered: Aug-12 | Than you Reg Rooster, I tyurned on my radio in order to enter the code, but I was not asked for the code. Instead, the radio played but make a "bleep" every 4-5 seconds. I found someone have the same behaviour after trying to make a reset (2+5 pressed when switching on), but no solution. Any hint ? |
Platinum Member Username: RegroosterPost Number: 10986 Registered: Aug-08 | Normally if it beeps then the radio requires a code. Try disconnecting for 10 minutes then enter the code |
