Your radio is made by CLARION and the only CLARION code that can be calculated (using a serial number ) anywhere on the Internet is if your radio also has a BARCODE SERIAL NUMBER beginning with C 7000000 + + + + on a separate label somewhere on the metal casing. (Note ...not beginning with CL.)
If not then it will only be available from your Main Dealer or a Decoding Service or your local Car Radio / Audio Store who will connect a laptop to read/recode the memory chip (EEPROM) inside your radio
pls can you help me, hi, i need help getting a code for my clarion radio cd its from a peugeot 605. Clarion PU-1587A S/No - 0001068 Model- 9631466880 Made in japan 286-8943-00 PU-1587A
pls can you help me, hi, i need help getting a code for my clarion radio cd its from a peugeot 605. Clarion PU-1587A S/No - C70000001068 But Ihave Problem I canot Enter code in my Radio,Ineed to make Reset for radio How make Reset????????? Thank you!
Please can you help me for a code clarion N°PU-2294(A) CL040130898014C C70000002625 FOR PEUGEOT BOXER with error 4 after the batterie broken Many than
Many thanks for your help, but we still have got the following message on the screen : error 4, and it does not work. Do you now how to delete this message ? thank you
pls can you help me, hi, i need help getting a code for my clarion radio cd its from a peugeot 605. Clarion PU-1587A S/No - C70000001068 But Ihave Problem I canot Enter code in my Radio,Ineed to make Reset for radio How make Reset?????????but we still have got the following message on the screen : error 4,(- - - -) and it does not work. Do you now how to delete this message ? Ilive my Radio ON 3H But Nothing.... PLS Help my Thank you!
How do I get rid of the error 2 message on my car radio when trying to put in the radio code. Do I need to disconnect the battery for 10 minutes or some other way? Car radio code and the error message
