Peugeot Phillips Radio Code
Username: Wysefool
Hi,I hope you can help me to get my radio code as i lost it when the battery was disconnected. Thank you in advance,Ernest. Phillips model No. "22RC200/65S" "TOW507" Production No. "FD0200460112880" "PHAPMFY0112880" "96 415 230 8001"
Username: Regrooster
Post Number: 10845
try code 3442
Username: Wysefool
hI, Thank you for the prompt reply with the code, and i am pleased to inform you that it is the correct code. Thanks again Ernest.
Username: Monsef
BMW
BLAUPUNKT
BAVARIA C II BP9455
7 649 455 040
BP9455A2569889 ?????????
codi _ _ _ _
Post Number: 10849
Username: Monsef
BE PATIENT !!
MULTIPLE posts....ARE IGNORED
Please do NOT flood the forum with the SAME request in more than ONE thread
It is not necessary....and can cause confusion
If you are in a rush then try an online Decoding service where you will get a reply straightaway....for a fee !
Username: Wayneparkyn
Hi
I hope you can help me to get my radio code as i lost it when the battery went flat. Thanks
Phillips model No. 22RC200/65
tom409
Production No FD0399299035168
PHAPKFX9035168
96 346 764 8000
Post Number: 10914
try code 1113
