Ford V Serial codes are not usually available for free from anywhere on the Internet (unless you can blag it for free from Ford) as access is required to the Ford factory database( via a Ford Dealer)...which is not commercially available as software.
Try here for cheapest option
ukbookshelf.co.uk/fordv
Otherwise try your Ford Dealer or a Radio Decoding Service
