Blaupunkt Radio Code
Username: Sergjeans
Hi All,
I'm hoping that you may be able to help me by providing me with the security code for a Blaupunkt radio/CD player. It's a unit in my Nissan Micra Model Nissan MMR CD-G Serial Number: BP538971317615 Part Number:7645389318
Username: Bogege
BG
Post Number: 464
Sergjeans try code :0407
Username: Sergjeans
thank you
Username: Bobby449
Hi I was wondering if you could help me to I've got the same unit that I need a code for but I don't know how to get it out the dash do I need a key for it?
Username: Bobby449
Username: Regrooster
Post Number: 10882
Username: Bobby449
Here is a video showing how to remove a standard radio from the dashboard.
A pair of extractors are required (available from Ebay etc ) but these can be made from 2 pieces of bent, wire coat-hanger or 4 small drills(using the blunt end) or 4 small Allen Keys or 4 small screwdrivers or 4 nails or even 4 darts.
An assistant is useful to pull the radio out whilst you are releasing the 4
securing clips
http://www.youtube.com/watch?v=urC-4NbXvDQ
note: on some radios , these 4 holes are protected by 4 small screws. These
can be unscrewed using the appropriate size of Allen key.
Username: Bobby449
Thank you but the unit I've got has no hole to put them in to it's the same unit picterd above
Post Number: 10886
Username: Bobby449
The photo shows 4 holes in the corners...Maybe covered with Allen screws
see also here
http://www.fitaudio.com/index.php?CategoryID=25
Username: Bobby449
Turns out those are just for show it's bolted at the back under the dash manged to do it codes on the back are bp738387814352 and 7647383318 if any can get me the code id be very greatfull
