New member Username: Laguna_bgPost Number: 1 Registered: Jul-12 | Model No 22DC279/62Z TOU678 RN279F10122283 PROD No FD0101270122283 |
Platinum Member Username: RegroosterPost Number: 10651 Registered: Aug-08 | try code 5388 |
New member Username: Laguna_bgPost Number: 2 Registered: Jul-12 | code 5388 is not good or i must to do something when i put that code. Maybe something like ENTER? |
Platinum Member Username: RegroosterPost Number: 10702 Registered: Aug-08 | PHILIPS RENAULT CODE ENTRY INSTRUCTIONS FOR CARS WITH A STEERING WHEEL REMOTE CONTROL (Note :If you don't have the [ ¬ ] button then push the thumbwheel in and some will have an [ A¬ ] button ) Turn on the radio and the display will show 'CODE' Use the Steering Wheel Remote Controls for code entry. Press the [ ¬] button then rotate the thumb wheel for the correct first digit Press the [ ¬] button then rotate the thumb wheel for the correct second digit Press the [ ¬] button then rotate the thumb wheel for the correct third digit Press the [ ¬] button then rotate the thumb wheel for the correct fourth digit If the correct code is now shown on screen, press and hold the [ ¬] button for up to 10 seconds to store the code IF THERE IS NO STEERING WHEEL CONTROL , THEN USE THE PRESET BUTTONS ON THE RADIO Press the First Preset Button repeatedly for the 1st digit to be displayed Press the Second Preset Button repeatedly for the 2nd digit to be displayed Press the Third Preset Button repeatedly for 3rd digit to be displayed Press the Fourth Preset Button repeatedly for 4th digit to be displayed Then press and HOLD Preset button 6 for 10 seconds to store your code (Note :Some radios use Preset Button 5 to store the code ) ==================================================== |
Bronze Member Username: AymantnPost Number: 30 Registered: Dec-09 | Hi all This is the simplist method to recover you renault car radio code instantly and for free, just take a look at this video tutorial or visit this car radio decoding site: http://car-radio-unlock.blogspot.com/ |
Platinum Member Username: RegroosterPost Number: 10705 Registered: Aug-08 | Beware of downloading virus and trojans! |
