Hopefully someone will be able to help I brought a Honda CRV (2000) about a year ago now it came with a Clifford alarm fitted to it (Solaris 5 with IntellIstart4) + it has started playing up.
It won't start, put the key in + it will turnover but nothing happens. If you use the intellistart4 to start it up it starts but has soon as you touch the break it cuts out again.
Can anyone help as this is driving me crazy?? Thanks
This alarm has a ignition immobilizer as well as a starter immobilizer and it seems like the ignition input to the alarm is faulty. I'm thinking that it's a white/brown wire. Make sure everything is still tight at the connections.
