Platinum Member Username: Regrooster
Post Number: 10805 Registered: Aug-08
Posted on IN ENGLISH The correct radio SERIAL NUMBER is required for a code First remove the radio from the dashboard. Then post the radio make+model plus all the letters+numbers on any labels,barcodes or stamped in the metal casing. This information can then be used to see if a code can be calculated |
